Blender 2.49b Axes Problem and Bug Round-up
Amoun
Post by Amoun »
I know this might sound like beating on a dead horse but I've looked hard and long around the forum and I haven't found a solution.
Got myself a SpaveNavigator and I'm using it with Blender 2.49b. I have to say I Love the heavy thing :), however there are a few things that need to be addressed.
Here are the issues I've noticed:
In the Control Panel
I) Blender Configuration Profile
As opposed to say, Acrobat, starting Blender does not change the configuration profile of the driver. I solved this by:
  • 1. Copying the default profile loaded by the driver:
    "C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\any.scg"
    To
    "C:\Documents and Settings\*\Application Data\3Dconnexion\3DxWare\profiles\user42.scg"
    2. Editing the following fields to (used notepad)
    APPLICATION_NAME = "Blender"
    EXECUTABLES = { "blender.exe" }
    3. Restarted the driver
This is not so hard, but not very user friendly, seems like something trivial to do on 3Dconnexion's side. Why hasn't this been done?
II) Tooltips
Where are the tooltips? A few lines of text would go a long way help make the driver friendlier.
III) Button Configuration (request)
It would be nice to be able to assign the "Reverse All Axes" function to a button.
IV)Advanced Settings
Assigning push up/down as "Zoom Direction" in the Device Configuration tab, swaps the "Spin" and "Roll" functions as well as the expected "Zoom" and "Pan". Is this wanted? What purpose does that serve?
In Blender
1. Turntable mode:
I) All Axes Reversed
I had to reserve all axes to get behavior desired; not a problem in itself but this comes into play, read on.
II) In Top/Front/Side view ("Dominant Axis" enabled)
Panning/Zooming brings the 3D view out of Top/Front/Side view, using the MMB doesn't. This is minor annoyance, but an annoyance nonetheless.
III) Spin/Roll
Since the functions are swapped in my Advanced Settings, see above, and both behave strangely in Blender, I'm simply going to refer to twisting the cap and pressing the R/L edges.
  • Top view:
    Twisting -> XY plane rotates round the Z axis
    Pressing R/L edge -> nothing (expected XY plane rotation around the Y axis)
    Front/Side view:
    Twisting -> Nothing (expected XZ plane rotation around the Y axis)
    Pressing R/L edge -> XY plane rotates round the Z axis
I know this is the "intended behavior", read post:
viewtopic.php?p=17696&highlight=#17696
But as "jjpr" noted, this ISN'T how the device should operate:
jjpr wrote:Technically, your description is mistaken. Three directions of translation and three axes of rotation constitute six degrees of freedom. If one axis of rotation is "locked" then there are only five degrees of freedom. Claiming that 6DOF is supported is inaccurate unless users can "unlock" that last axis. Is that possible?
What's also strange about twisting and pressing the R/L edges is that depending on the viewing angle, their effectiveness is inversely proportional. That is, when twisting starts to loose effect, pressing the the R/L edges becomes more effective and vice-versa. This bug is particularly annoying as it ends up being a guessing game.
2. Fly mode
I) Orthogonal/Perspective view
Switching in and out of Fly mode without moving the cap doesn't affect the 3D view. The moment you touch the cap in Fly mode the view goes into perspective mode (as it should), but it doesn't switch back to ortho when you go back to Turntable/Transform mode.
II) Axes and "Zoom Direction"
All the axes behave in the opposite direction than they do in Turntable mode. Same goes for the zoom/pan behavior. This makes this mode unusable, I'm not going to spend my time switching the axes in the driver. Good thing I don't use it in any case.
III) Speed
The speed is all over the place and way off. Again major issue.
3. Transform mode
I) Manipulating objects
  • Action performed -> Axis direction
    Move along XY (panning) -> Reversed
    Move along Z (zooming) -> Unaffected
    Tilting -> Reserved
    Twisting Cap -> Reversed
    Pressing R/L Side -> Unaffected
I don't know what's going on here, but with the way the axes are affected I can't use my SpaceNavigator in Transform mode.
II) Action confirmation delay
The delay between stopping the movement of the cap and Blender commiting the action to the undo stack is way too short. The undo stack gets filled with way too many actions and you end up having to increase the number of undo steps to an insane number.
III) Using the G,R and S KEYS
  • GKEY: Works as *expected* when I adjust the axes directions, see point I).
    RKEY: Pressing the R/L side is the only direction that works. Being able to tilt would have been great.
    SKEY: Nothing, would be nice to have some direction affect the scale.
CONCLUSION:
Well, I think that about covers it ;). Many of these issues are minor and don't really affect my usage (I'm a noob, so no clue if that will change), for the moment though here's what I'd want to fix asap:
  • 1. Transform mode -> I) Manipulating objects: Unusable at the moment :(
    2. Transform mode -> II) Action confirmation delay: Undo becomes useless, too many steps in the stack
    3. Turntable mode -> III) Spin/Roll: Being able to Roll the view would be great
Are there any solutions to these problems? The Top 3 being the most important.
Despite all of this, I think the SpaceNavigator is an awesome product and the 3Dconnexion team have done their homework. Just a little more and it could be better than Angelina Jolie (okay, maybe not but you get the idea :).
2disbetter
Post by 2disbetter »
Thanks for the tip on the editting of the config file.
So far (i'm using build a not b) I can concur with the speed issues. ALthough it seems to mainly affect object rotation on the horizontal axis.
The front, back, side, top buttons don't seem to work in Blender. Again I just started tweaking the controller within Blender.
I'll report back when I've got more info. Just wanted to add to this thread and make sure it maintains some visibility.
2d
SpacePilot Pro
Amoun
Post by Amoun »
For the front, back, side, top buttons to work in Blender you could try remaping them to num1, ctrl+num1, num3 and num7 respectively. Wish I had a SpacePilot Pro to tell you if it works ;).
2disbetter
So after I thorough review of all the commands I use, I have them all mapped to the controller. The ONLY problem so far is that long presses on the orientation buttons do not result in ctrl+numkey responses. This can be worked around by just holding down ctrl and then pushing the key.
At this point, I'd say a little more tweaking and I'll have the controller able to do everything I would need to use the keyboard for.
2d
SpacePilot Pro
