Spacemouse Enterprise
I currently use Creo 3.0 and have recently purchased the Spacemouse Enterprise. Everything works great, but the LCD doesn't display any text or icons for the 12 programmable buttons. I have the updated/current driver, can someone give me some direction to get this fixed?
Re: Spacemouse Enterprise
Hi ADK,
do the modifier keys, like ESC, Ctrl, Alt, Space, etc work like expected?
If not it might be that the plugin is not installed or perhaps just not loaded. The information provided by selecting the "Info" button in the Auxiliary Applications window found in the Tools ribbon will show if the plugin has loaded. You should see an entry for the 3DxProEngineer plugin there.
Do you see anything if you open a browser window or an Explorer window? What does the LCD show then?
