I have had no luck getting my Space Pilot Pro to work in Lightwave Modeler. It works in Lightwave Layout. It was not an issue a year or so ago.
Yes, I just downloaded and installed the latest Driver.
Does anyone have an answer for this? I'm ready to start looking for a different 3D Mouse.
Is Lightwave Modeler Still Supported?
Re: Is Lightwave Modeler Still Supported?
Hello 61vdc,
which driver version are you using? I strongly recommend to update to the current version - 3DxWare 10.5.5 - if you haven't yet done so.
In case you still have problems you have to remove the existing settings as described here.
