Another post about this topic can be found here: viewtopic.php?f=19&t=932&p=3563&hilit=C+builder#p3563
However, the proposed solution doesn't help me. I'm having troubles linking my C++ Builder application (Tokyo 10.2) against the static compiled libs that come with the SDK. I know they need to be converted to the OMF format that C++ Builder uses, but the convertor tool simply strips the libs iso really converting them.
Anyone knows how to use/convert the libs to be able to create C++ Builder applications that use the 3Dconnexion devices?
Any other way to go to be able to use 3Dconnexion devices with C++ Builder?
Thanks a lot for any clue or suggestion
using siap and math libs with C++ Builder
Re: using siap and math libs with C++ Builder
You can't use COM?
It wouldn't surprise me, since that is even farther down the Microsoft rabbit hole than their obj format.
