My solidworks was fine until I added the 3Dconnexion space navigator. I can work with an assembly, open a separate part window, work on the part but after I save the part and then upon closing the part window, solidworks crashes.
It is very frequent. It appears to be correlated with memory use because if I open and close a window after a fresh start it is okay but after 10-30 minutes of work, it will almost always crash when I close out the windows or sometimes upon PDM part check-in.
I removed the driver and solidworks is now fine.
3DxSoftware32_v3-10-1_r852 Windows XP SP3.0 Solidworks 2008 Premium SP5.0
Solidworks Crashes when closing part window
