I have installed / enabled Solidworks Workgroup PDM plugin.
The SW file menu now has "Save and Check In" menu item.
I can't seem to find it in the 3Dconnexion button setup...
Solidworks "Save and Check In"?
Re: Solidworks "Save and Check In"?
Hi Borisw37,
the command is not available in the driver because it doesn’t come from SolidWorks, but from SolidWorks Workgroup PDM. The plugin only shows commands from SolidWorks. But if you know a keyboard sequence to launch the "Save and Check in" command you can easily create your own button mapping by entering that.
