Spacenavigator & Blender 2.5
Hello Dudes & Dudettes,
I have tried installing the drivers for the Spacenavigator to work with Blender 2.5, but without any luck.
Basically I downloaded the 3DxBlender2_47-MacOSX, and in the readme file it says that I have to copy/paste the 3DxNdofBlender.plug file into the plugin folder in Blender. The problem with this Spacenavigator driver is that there are 2 folders that are called i386 and ppc, that both have the 3DxNdofBlender.plug file. I have tried copying both folders in Blenders plugin folder and also copying them individually - and still nothing happens.
I am on a MAC 10.5.8 and trying to use Blender 2.5 Alpha.
Does anyone have any hints to what I can do in order to use my Spacenavigator??
I would really appreciate it!!
A Google Summer of Code student named Mike Erwin is working on a new and better integration of exotic and fancy input devices in blender 2.5x.
He has menconed that he is working with a space navigator. Her is some progress updateds:
http://lists.blender.org/pipermail/soc- ... 00065.html
Space Navigator not working with blender 2.5 beta yet
Any news or hope that my Space Navigators will work with blender? The beta looks really good. I sure wish my Space Navs worked with it.
Space navigator and 2.59 RC
Space Navigator now works with Blender 2.59 RC!
-Dick
-Dick
bernardo_86
If it is the same as the PC, the interface they designed does panning by holding down the keyboard's shift key. You can also do fly mode (shift+f). To change the center of rotation, right click on an object and press the 3Dx device fit button. The center of rotation will now be at the center of that object.
bernardo_86
Thanks! but.... you mean there's no option to do it like in the old versions? For example this guy here is moving around using only the 3-D mouse: http://youtu.be/z0F0ammzf34
It makes no sense to have to use the shift key on a spaceNavigator... p.s. I don't like the fly mode at all
The blender integration was done by the blender community. The developers are very responsive to user suggestions. I assume they will be enhancing the interface as users, like you, contribute your insights of its actual and desired usage.
I'm not an animator. I can't contribute much to the design process. But I think, at least an option to turn on/off the simultaneous panning would be a good suggestion.
Admittedly, you don't have to chase the rotation point around with this interface. It only moves when you want it to. I think there is something to be said for that.
