Hi all,
I'm using Manjaro Linux and installed the space mouse drivers for a wireless space mouse. When I start the driver with /etc/3DxWare/daemon/3dxsrv -d usb I get the error "/etc/3DxWare/daemon/3dxsrv: symbol lookup error: /etc/3DxWare/daemon/3dxsrv: undefined symbol: xmFormWidgetClass".
Could anyone help me to solve this problem?
Thank ya,
Schwanzlurch
Manjaro Linux and Wireless Space Mouse
Re: Manjaro Linux and Wireless Space Mouse
you need to install Motif for the driver. You can use openMotif.
Note that we officially support only SUSE Linux 9.3, 10 and 11 and Red Hat 4 and 5.
Yadand
- Location: https://diceus.com/best-countries-to-ou ... velopment/
Thanks for this helps, I had the same issue!UtaSH wrote: ↑Thu Aug 16, 2018 1:36 am Hi,
i got the SpaceMouse Wireless for christmas. i also use manjaro linux and can't get it to work.
i followed the instructions and first did (with sudo where necessary):
then:
the install script seemed to run successfully.
but if i try to start the driver with:
i get this error message:
Error: Could not open USB port or no supported device found! Exiting!
so i guess (like mentioned in the instructions for SuSE Linux 10.x) in manjaro linux the usbfs isn't mounted by default.
i tried:
which resulted in:
mount: /proc/bus/usb: mount point does not exist.
does anyone have any hints? i would be very thankful!
cd /usr/lib64
ln -s libXm.so.4 libXm.so.3Code: Select all
tar xfz 3dxware-linux-v1-8-0.x86_64.tar.gz install-3dxunix.sh
./install-3dxunix.shbut if i try to start the driver with:
/etc/3DxWare/daemon/3dxsrv -d usbError: Could not open USB port or no supported device found! Exiting!
i tried:
mount -t usbfs none /proc/bus/usbmount: /proc/bus/usb: mount point does not exist.
(i forgot to mention that i also installed openmotif.)
I recommend not to use
but
sudoCode: Select all
su -Uta
mae4_king
- Location: https://www.innovecsgames.com/blog/game ... op-titles/
Is it possible to add the right drivers to Manjaro to allow me to run at full speed?
