Setting retention
girarde
Setting retention
Post by girarde »
Are custom button settings retained if the mouse is moved to a different computer?
Re: Setting retention
Most user customizations are saved in the appdata Roaming directory (cfg/xml files).
Some user changes may be saved in the registry, depending on the app and version.
If you are using Active Directory to roam that from machine to machine, the Roaming cfgs will be seen on other machines.
If not, they will not, but you can use the GUI's export/import function to manually copy your saved changes (cfg files) to the other machine.
