Assign keyboard shortcuts to rotation axis
I am using Clip Studio Paint with Space Pilot Pro, and I customize almost everything I need, but I had no luck assigning any keyboard shortcuts to any rotation axis. I need to assign keys [ and ] to Rz axis (I have also tried other keys), but, I have no luck. I do not have problem assigning mouse wheel actions to axis events, though. This is not something specific to Clip Studio Paint, since eg. Notepad doesn't work either. I have tried to assign Key, Keypress, Macro... using keywords for modifiers, press and hold... all combinations I could imagine and nothing seems to work. Any ideas?
Re: Assign keyboard shortcuts to rotation axis
The GUI can't help you with this, but if you can edit the cfg file for the app, here is one example of how you add two keys on an axis (positive and negative direction). I think these send A and S keys. You need to replace the <Key> values with the values for the keys you want to send. You can look them up online, but the easiest way is to create a kb macro with our GUI and see what value it saves in the cfg file.
<AxisBank Default="true">
<Name>STR_DEFAULT_BANK</Name>
<ID>Default</ID>
<Axis>
<Enabled>true</Enabled>
<Input>
<Min>0</Min>
<Max>511</Max>
<Deadband>200</Deadband>
</Input>
<Output>
<RepeatStyle>PressAndHold</RepeatStyle>
<KeyStroke>
<Key>8</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<KeyStroke>
<Key>14</Key>
</KeyStroke>
</Output>
</Axis>
</AxisBank>
Thank you! Somehow your code work like a magic, even I'm sure that I have tried exactly the same code, which doesn't work in my case! However, your code did the trick! Thank you again!
Hello, it really works. Thank U. Maybe you also know how to assign not just a key but a key combination, for example CTRL+ PAGEUP and CTRL + PAGEDOWN?
Thanks a lot
Thanks a lot
I believe this still works. For example, this adds a Control key Modifier to KeyStroke (PageDown).
Possible Modifiers are: Control, Shift, Alt, Windows, LeftMouse, MiddleMouse, RightMouse.
You can specify more than one.
If you specify conflicting Modifiers on different axes that may be active at the same time, I do my best to deliver what you asked for. That doesn't mean the app will receive it though. Many apps, especially games, poll the keyboard. They will see whatever the state is at the moment it asks. It is best to use a filter to separate the axes in this case.
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<Scale>1.00</Scale>
<MaxEventRate>40.00</MaxEventRate>
<Modifiers>
<Modifier>Control</Modifier>
</Modifiers>
<KeyStroke>
<Key>4e</Key>
</KeyStroke>
</Output>
</Axis>
Thanks again, i tried it but did not work for me.
What i am trying to do is to assign CTRL+pageup and CTRL+pagedown to X axis movements in chrome, to switch between tabs.
This works for me. Possibly you were not making the changes to the correct file?
I've made some refinements that might help.
1) I find it difficult to push sideways in X. I find it much easier to tilt left/right. I've assigned ctrl+PageUp ctrl+PageDn to that axis (Ry).
2) I've turned off the other axes (<AxisFilter>Dominant and all the other Axes<Enabled>false). The cross talk is very difficult to control with the hand.
3) I've specified a dead region between +/-200. You have to exceed that before anything happens.
4) I've changed the repeat rate to 1/second. It goes way too fast otherwise.
It's not perfect. For one, it may tab in the opposite direction you want. You can change that if you don't like it.
More importantly, sometimes it doesn't release the buttons, so it keeps tabbing. Tap the cap and it will stop. That sure looks like a bug, and sounds familiar.
<Device>
<VendorID>0</VendorID>
<ProductID>0</ProductID>
<AxisFilter>Dominant</AxisFilter>
<CurrentAxisBank>Default</CurrentAxisBank>
<CurrentButtonBank>Default</CurrentButtonBank>
<ID>Default</ID>
<Axis>
<Enabled>false</Enabled>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>-200</Max>
</Input>
<Output>
<Scale>1.00</Scale>
<MaxEventRate>1.00</MaxEventRate>
<Modifiers>
</Modifiers>
<KeyStroke>
<Key>4e</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>-199</Min>
<Max>199</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>200</Min>
<Max>511</Max>
</Input>
<Output>
<Scale>1.00</Scale>
<Modifiers>
</Modifiers>
<KeyStroke>
<Key>4b</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
</AxisBank>
Hi, I'm trying to Assign keyboard shortcuts to rotation axis, too,
Would you help me with more details as in which file to modify? and where the file is located(file path)?
and if the Software I'm trying to program the Axis is not in supported software list, what would be the steps to follow to create a new cfg file?
Thank you!
WILL
Thank you!
WILL
Hello WILL,
Each application needs a cfg (XML) file that describes what the driver should do when the application is in focus.
If we don't ship a cfg for an app, the driver will use a default one. If you make changes in our GUI while your app is in focus, a file specific to your application will be written. You can then modify that cfg.
The steps would be:
1) Start our driver
2) Start our GUI (3DxSmartUI)
3) Start your app. Make sure it has focus.
4) In our GUI make some change for your app. E.g., turn off and on all the axes in the Advanced panel.
You now have a cfg for your application in %appdata%\3Dconnexion\3DxWare\Cfg (yourapplicationname.xml).
It has entries for the axes on your device which you can now edit.
The next step is to figure out what you want those axes to do. That is, how to cause panning/zooming/rotation in the application. Since the application does not have 3D mouse support, you have to trigger these actions some other way. Some applications support a joystick. Most support the 2D mouse in some way. Some work with keyboard keys (arrow keys, ASDW, etc). The app is unlikely to ever be as smooth as if it had proper 3D mouse support. Only the app developer can add that, or potentially a plugin can be written by someone else.
Once you have decided which to use, you can follow the template above for telling the driver what to do.
And, of course, asking here for more detailed help.
For kb shortcuts, the syntax is not meant for human consumption. Let the GUI write the XML for you by assigning the keyboard shortcut to a device button. That gives you the correct syntax (<Key>xx</Key>) for use on an axis. The xx is hex for the HID code of the key. It is specific to a kb locale.
The steps would be:
1) Start our driver
@jwick,
Apologies for bringing back the old thread but this is on topic.
Thank you for this. Though I followed the steps to generate a app specific xml file for the baseline to edit and it does not work. An application specific file is not created in appdata. In fact I can't get the software to generate any custom file for any application, carefully testing those are not listed on your support list with default cfg files. I can see a file called LCDCfg.xml being updated every time I make changes but the axis syntax is not added, just the button controls which I can change and see changed in the xml. It is like the mouse only uses a default cfg file even though the name of the difference apps I try to customized appears in the header of 3DxSmartUI.
Any thoughts what is going on here?
I am using the latest software with a spacemouse compact.
Thank You,
Thank You,
There are two related, and commonly confused, dirs:
%appdata%\3dconnexion\3dxware\cfg
%localappdata%\3dconnexion\3dxware\cfg
The user changes are kept in the first one. (Type %...% into your explorer window.)
It probably expands to something like: C:\Users\your-user-name\AppData\Roaming\3Dconnexion\3DxWare\Cfg
The latter is more or less temporary files.
It's there a specific reason to not add this to the software so everyone can just configure it to their likeness rather than being limited? If you guys want to keep the UI just simple, you could always add some kind of "advanced profile editor" as a side executable that has to be opened manually and not through the default menu.
Hi
i got this working thx a lot
i assigned wasd for the movement of the camera in a game.
You can press two buttons, such as D and W, to move diagonally.
But with the Space Pilot, only one works.
Is there a hidden option to send both buttons when both axes are triggered?
hmm cant find to edit a post.
so i send another one
I also wanted to ask, if somebody know the lines to emulate a joystick? for keys it is KB_Keystroke and for joystick?
I was dumb xD it was on dominant... easy fix ^^Kijan wrote: ↑Sun Jun 01, 2025 1:14 am Hi
i got this working thx a lot![]()
But I created a python script to easily edit the axis in the configuration file.
If someone comes across this thread
https://github.com/Kijan/SpacePilot-XML-Editor
