SpaceMouse and SDK
SpaceMouse and SDK
Hello, I am in China. I can't register on the official website to download the SDK. After I fill out the registration information, clicking the submit button does not respond. Just like the picture below. What should I do then?
Re: SpaceMouse and SDK
Hello lufei,
I apologize the problems you encounter. I haven't found any records for the email adress that you used to register for our forum.
Which browser did you use? Please remove all cookies and then try it again.
If this doesn't help please try another browser.
In case you weren't successful please contact our Technical Support Team with the same email address that you used to try to register.
hello
I have already registered the 3dconnexion account and downloaded the SDK package, but I have not found the installation instructions and instructions for using sdk under ubuntu. Would you give me a copy?
thanks!
lufei
thanks!
lufei
My system is ubuntu18.04.The following problem occurs
when I use the jstest command to detect device information.
sl@op:~$ sudo jstest /dev/input/event17
[sudo] password for sl:
Driver version is 0.8.0.
jstest is not fully compatible with your kernel. Unable to retrieve button map!
Joystick (Unknown) has 2 axes and 2 buttons.
Testing ... (interrupt to exit)
jstest: error reading: Invalid argument
