Windows dead zone/threshold settings?
zacaj
Post by zacaj »
I'm using a SpaceMouse compact with windows, and I can't find any settings to control the deadzone. If I plug it into my mac, the settings have an option for 'threshold' to control this. Is this not available on windows?
Re: Windows dead zone/threshold settings?
It can be set at the global level, the application level or the axis level:
Global.xml: GlobalCfg/Settings/Deadband
An AppCfg: AppCfg/Settings/Deadband
or AppCfg/Devices/Device/Axis/Input/Deadband
Windamyre
Post by Windamyre »
Thanks for this! I was also running into problems with everything short of a stray breeze sending my viewport spinning.
Why this isn't an option on the settings window is beyond me!
For those who don't know how to apply the setting (and I was one of them until I did more looking), here's the rest of the info:
--Find the file. For me it was in c:\users\Windamrye\AppData\Roaming\3Dconnexion\3DxWare\Cfg\Global.xml as I'm a Windows user and my username is Windamyre. Your user name will likely be different. Also, the AppData folder is hidden by default, but you can un-hide it using https://www.howtogeek.com/howto/windows ... ows-vista/.
--If the file doesn't exist, someone said you can force it to be created by turning the LEDs off and on again from the task bar.
--Make a copy of the file. Something like Global.bak or something just in case you screw up.
--Open the original file in any text editor. Notepad works. Look for the part at the end where it says "</Settings><Devices/>"
--Just before that part insert the text below. The number is the size of the deadband, so you'll want to adjust it to suit
<Deadband>100</Deadband>
--Save the file.
--I rebooted my PC. Not sure if that was necessary, but I wasn't sure how else to get 3DxWare to reload the setting.
That should do it. Again, I have no idea why the hell they didn't include something like this in the settings window. Baffles me.
