Not working with AutoCAD 2020 (no plugin)
bogordo
Post by bogordo »
After last update to Spacemouse enterprise it is not working, curiously i can't see the Acad2020 driver in folder:
Any ideas?? thanks
Re: Not working with AutoCAD 2020 (no plugin)
Read the ReadMe.txt file under the 3DxWare AutoCAD add-in folder, there's only 3Dconnexion Add-in for AutoCAD 2007-2010 and 2012-2018.
Hi bogordo,
AutoCAD 2020 is supported since 3DxWare 10.5.13. So if you have the latest version installed (currently 10.6.4) you should have support in AutoCAD 2020. In case you have problems I recommend that contact our Technical Support Team.
There's no mention of AutoCAD add-in update for AutoCAD 2020 in the 3DxWare v10.6.4 release note document, the PDF only include this:
3DxAutoCAD 5.6.0 2019 Jan 24
3DxAutoCAD (x64) 5.6.0 2019 Jan 24
And the 3DxWare64\components64\3DxAutoCAD\3DxAutoCAD64.msi file creation date is February 12, 2019.
While 3DxWare64\components64\3DxAutoCAD\3DxAutoCAD64.msi\Data1.cab\_dxautocad.arx20 timestamp is January 24, 2019, date is ahead of AutoCAD 2020 official release date March 27th 2019 by Autodesk.
https://blogs.autodesk.com/autocad/intr ... d-lt-2020/
By The AutoCAD Team March 27, 2019
The ReadMe.txt file modification date is April 19, 2018, totally out of sync.
There must be some lack of human labor resource.
