3DS Max move locked camera
Alpenshiva
Post by Alpenshiva »
Hi 3Dconnexion Team!
Driver Version 3DxWare64_v10-6-0_r2972 is the last that works correctly in 3DS Max with Space Pilot Pro.
Since then it is possible to move a locked camera in orbit.
This is annoying, since there is no undo command for this bug.
Please fix this in your next release.
Thank you, AS
ariachris56
Re: 3DS Max move locked camera
Post by ariachris56 »
Problem is sorted out?
jens.c
Post by jens.c »
This is still very much happening. So annoying that you lock cameras, later accidentally hit the space mouse and camera is moved and it ctrl+z doesn't work. Better hope you have saved prior to that so you can reimport camera from same file. This hasn't always been like this.
3ds max 2020.3
win10
spacemouse pro
3dxware 10.6.3
3dxWinCore 17.6.3.16588
thad
Post by thad »
I have the same issue with the same 3dsmax version.
Hi all,
we are tracking this issue with our internal bug number WIN-563. We expect this to be fixed with our next driver release (3DxWare 10.6.5).
tehamnes
Post by tehamnes »
Locked cameras are still moving with 3dxware 10.6.5. (3ds max 2020 and wireless spacemouse)
Or am I missing some setting?
thad
Post by thad »
UtaSH wrote: Tue Feb 04, 2020 8:13 am Hi all,
thanks, latest driver fixed my max2020 issue.
mbonk
Post by mbonk »
tehamnes wrote: Sat Feb 08, 2020 5:05 am Locked cameras are still moving with 3dxware 10.6.5. (3ds max 2020 and wireless spacemouse)
Please give us a testcase so that we can reproduce the issue.
vinigor
Post by vinigor »
Only target-cameras are moving. Even if target locket too.
loofer
Post by loofer »
Yeah, I'm getting the same too on 10.6.5, physical camera moves when locked but only if targeted, if not targeted it remains locked.
vinigor
Post by vinigor »
I found another interesting bug. It happens with not locked cameras when automatic vertical tilt correction is on. It even happens when the driver is stopped. Only uninstalling helps.
https://drive.google.com/open?id=1jA-70 ... L3HvN3pGT7
mbonk
Post by mbonk »
vinigor wrote: Thu Feb 13, 2020 9:30 pm I found another interesting bug. It happens with not locked cameras when automatic vertical tilt correction is on. It even happens when the driver is stopped. Only uninstalling helps.
Very strange. Thank you for reporting this.
mbonk
Post by mbonk »
vinigor wrote: Tue Feb 11, 2020 3:36 am Only target-cameras are moving...
Sorry, that we missed this...
ihabkal
Post by ihabkal »
thank you for reporting this I have been having this problem for over a year and it is killing me. as soon as you introduce lens shoft to a physical or corona camera then when you save file, or do anything while in the camera viewport it shifts on it's own, the slightest touch of the nob send the camera shifting a large distance. I have three 3d connexion units one of them is the latest most expesnive one and they are all expensive paper weights now after a whole year and several versions of the drivers doing this max 2020.3
Hi vinigor,
We're tracking this as WIN-621 and the fix is expected to be delivered in v. 10.6.6 of 3DxWare 10 by mid-April.
