when i have the 3DxMaya.dll loaded in maya (2017) and i try to move an object in the viewport it works fine for a few units, but when the object goes a bit far from its origin the viewport start flicking like crazy. if i move the object even further maya just crashes.
so i basically cant work with my 3Dconnexion, if i do i cant manipulate anything inside maya.
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x00000068
Fault address: 482C1386 in C:\Program Files\Autodesk\Maya2017\bin\Shared.dll
0001:002F0386 Logical offset (see .map file for location)
maya 2017 - crash while moving objects
Re: maya 2017 - crash while moving objects
Hi Felipeitsui,
Thanks for your post, can you please create a technical case for creating a bug for this issue and to get some other information needed on your end.
Please click on this link to send a technical case then will be able to contact you directly for this issue
https://www.3dconnexion.com/service/tec ... mular.html
Regards,
Abdul. A
Regards,
Abdul. A
felipeitsui
I Cant, when i try to login on my 3dConnexion account it just send me an email to reset my password all the time.
Hi felipeitsui,
we received your request and have replied to it. Did you receive our email from January 20th?
