Keeping Custom Button Configurations
JCrilly
Post by JCrilly »
I am having trouble keeping my custom button configurations. I have the USB SpaceExplorer for using with Inventor 2011. My drivers and Inventor Service Packs are all up-to-date. (OS : Win 7 64bit)
I set the buttons to do what I want (I reset most of the buttons to do something different), and save the profile. "Automatically Save Configurations" is also checked in the Options menu.
Every time I close and re-open Inventor, the default settings return and the profile I created also has the default settings.
Is there a step I am missing?
Hi JCrilly,
the 3DxInventor add-in provides a button mapping editor within Inventor. This should normally open if you press the Panel button on your device.
Do you have the 3DxInventor add-in loaded? (Go to Tools -> Add-Ins and check if 3DxInventor is in the list.)
The button mapping editor overwrites the button configuration from the 3Dconnexion Control Panel.
JCrilly
Post by JCrilly »
Thanks uludwig. That was what I needed.
I just had to re-load the 3DxInventor add-in and was able to permanently customize the buttons.
