I'm running into an issue on macOS Catalina 10.15.3, using 3DxWare 10.6.3 where I'm unable to export settings for any app. When I attempt to export, a small ui element briefly flashes on the bottom left corner of the screen and disappears.
I'm left with the screen image attached, unable to enter text or navigate anywhere. I've tested this on 3 separate machines with the same settings and I run into the same exact situation. Is there any fix/work around?
Unable to Export Settings OSX 10.15.3
- Attachments
- Screen Shot 2020-03-03 at 1.32.13 PM.jpg (35.12 KiB) Viewed 5161 times
Re: Unable to Export Settings OSX 10.15.3
Hi breckten,
would you please check if the issue is the same with the current driver 3DxWareMac 10.6.4. You can download this version here.
