missing advanced settings?
3dcal
Post by 3dcal »
Hello
I'm trying to find this settings screen on my MacOS 3dxware and can't find it.
image (5).png (73.57 KiB) Viewed 8124 times
It does show up on my windows 10 laptop. Anyone know where i can find these sliders on a Mac?
thank you
Alex
happydorid
Re: missing advanced settings?
Post by happydorid »
I have the same issue. The only way I've found to change the rotation settings is by setting them in a radial menu, but the settings don't save.
The new driver has fixed many issues I was having with the software so I don't want to downgrade.
This is so frustrating!
aalsalihi
Post by aalsalihi »
Hi 3dcal,
On Mac, we have a different UI format which is different than windows. When you open our setting window, you should see the attached screenshot and to control the axes or movement of the knob it should be under axes in our driver properties.
- Open 3Dconnexion Home
- Click on Properties
- Click on Axes
Tilt, Spin and roll should be able to control the rotation of the object. You need to make sure the application name is selected under Configure then change the dropdowns below accordingly.
Regards,
Abdul. A
