Hi everyone,
I recently started using the SpacePilot with driver 10.4.10 and Fusion 360.
Usually it works correctly, but occasionally the SpacePilot reads Fusion360 as Inventor, which throws off a lot of the tools that I use in Fusion 360. How can I keep this from happening?
Re: SpacePilot reads Fusion360 as Inventor
Hi qriusGate,
it might be that you have a messed up configuration file. Try if removing your user-specific settings would solve the issue. See here how to do that.
In case this doesn't solve the problem I recommend that you contact our Technical Support Team. They might ask you for a log file of a session where the problem occurred. See here how to create a log file of the driver.
