Hi!
I installed the driver "3DxWare64_v10-6-7_r3198" this morning. In SketchUp 2020 the rotation doesn't work and the program crashes.
Has it happened to someone else?
Thanks and regards:
Antonio.
Driver "3DxWare64_v10-6-7_r3198" crashes on SU 2020
Re: Driver "3DxWare64_v10-6-7_r3198" crashes on SU 2020
Hi el.anutan,
did you remove the existing settings during installation? If not please check if the instructions from this FAQ solve the problem.
Which exact version of SketchUp 2020 are you using?
Please check in SketchUp under Windows -> Preferences -> Extensions if you have the 3DxSketchUp extension and if it is loaded.
Let us know what you find out.
Hi, UtaSH!
It works now! I had to stop and start the 3DxWare application for SketchUp. It goes very well.
The only thing is that the browser menu does not appear, but it is not very important. With the 3Dnavigator working, I'm fine.
Thanks and regards:
Antonio.
Thanks and regards:
Antonio.
