Spacemouse Pro Wireless - Control is laggy and does not stop momentum Maya.
milocraft
Post by milocraft »
Spacemouse Pro Wireless - Control is laggy and does not stop momentum Maya. It was working fine a few days ago. Now if I barely touch the controller the window starts flying and never slows momentum. I can still control it, for example, pushing or pulling in opposition to the motion to try to counter it, but the momentum continues and the window continues moving. I have to eventually close Maya to get control back. This essentially breaks the controller. Do you have any suggestions about how to fix this?
Software
3DXWare 10.6.5
3DxWinCore 17.6.5.17089
Software is up to date.
Devices:
SpaceMouse Pro Wireless FW:4.38
SpaceMouse Pro Wireless Receiver FW:4.38
Maya 2018.5
Re: Spacemouse Pro Wireless - Control is laggy and does not stop momentum Maya.
Uninstall 3DxWare v10.6.5, and roll back to to 3DxWare v10.6.0, no upgrade of 3Dconnexion driver 3DxWare upgrade for Maya 2018 so far. It should works.
Hi milocraft,
did you unplug and re-plug the device and/or the receiver? Does it make a difference if you connect the device with the cable?
Have you tried different USB ports?
