Last update completely broken for me. The only version that works for me is 10.5.15
When installing latest version, rotating does not work. Only panning side to side, forward backwards, and up and down.
Using the buttons on the spacemouse pro crash 3ds Max, both 2020 and 2021.
Please help me.
Latest update not working for 3ds max
Re: Latest update not working for 3ds max
hello,
with the new driver in 3ds max the rotation starts working when there is at least one object in the scene , a blank open 3ds max file the rotation dosent work for me ... when you use 2020 best working driver for me is 10.6.0 , BUT you have to install with advanced options and "deleted old Userdata" or "erase previews User data" i dont have it in english installed i dont know how its called in english ... when installng delete the old datas like a clean install on 2020, in max 2021 you need the new driver but i noticed some kind of flickering on the gizmo where you move/rotate/skale object or subdivisions like 2 gizmos flickering back and forth ...
sorry for my english i hope this helps
Greetings
Greetings
Lieber von Rembrandt gemalt, als vom Leben gezeichnet!
Sprachen/Languages/Idiomas: Deutsch/English/Español
