I'm trying to get the Driver_Desktop_ToggleGrab working.
My goal is to have a fixed button to toggle between the program profiles and a general profile, where I have some day-use shortcuts
I managed to get some things working like the shortcuts, axis movements, etc.
I have overwritten thee global.xml and desktop.xml file in the program files and the Appdata folder with the files shown below.
I did this, because It seemed that the file in the PF folder overwrites the appdata files after a restart.
However I'm struggling with some other issues:
*The displayed title is not a fix name, though I have set is as "general" in my desktop.xml
*The <grab>Hard<\grab> in my desktop file is always been overwritten by <grab>None<\grab>
*When I unplug the spacemouse, and replug the driver stops working.
*When I'm at the program profile and like to change some buttons by the GUI, the moment I click the GUI, I see the 3DxSmartUi title appear in the buttons windows, and I can only change the buttons that control the 3DxSmartUi instead of the programs
Global.xml
<?xml version="1.0" encoding="utf-8"?>
<Global Default="false" xmlns="" CfgFormatVersion="1.3" ThisFileVersion="2.0">
<CfgProperties>
<ID>ID_Global_Cfg</ID>
<Name>STR_GLOBALCFG</Name>
<InheritsFromID>ID_Global_Cfg</InheritsFromID>
</CfgProperties>
<MacroTable>
<MacroEntry>
<ID>Next_Screen</ID>
<KeyStroke>
<Modifiers>
<Modifier>Control</Modifier>
</Modifiers>
<Key>E3</Key>
<Key>1B</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>PrintScreen</ID>
<KeyStroke>
<Key>6E</Key>
</KeyStroke>
</MacroEntry>
</MacroTable>
<Settings>
<OverallScale>1.00</OverallScale>
<Deadband>0</Deadband>
<ResponseCurve>1.70</ResponseCurve>
<SystrayIcon>true</SystrayIcon>
<InstallerAutoCheckForUpdates>true</InstallerAutoCheckForUpdates>
<LastAutoCheckForUpdates>3-7-2020</LastAutoCheckForUpdates>
<LEDsEnabled>true</LEDsEnabled>
<OnScreenDisplayEnabled>true</OnScreenDisplayEnabled>
</Settings>
<ButtonActions>
<ButtonAction Type="Driver">
<ID>Driver_ShowDriverGUI</ID>
<Name>STR_DRIVER_SHOWDRIVERGUI</Name>
<Image>
<Source>[driver_images:Driver_ShowDriverGUI.png]</Source>
</Image>
</ButtonAction>
</ButtonActions>
<AuthorInfo>
<DriverVersion>17.6.8.17515</DriverVersion>
<LastChange>
<Tool>3DxService.exe</Tool>
<Version>17.6.8.17515</Version>
<Date>2020:7:5:3:20:23:14:199</Date>
<User>dkyndt</User>
</LastChange>
<Created>
<Version>17.6.3.16588</Version>
<Date>2019:10:2:8:10:59:19:315</Date>
<User>jwick</User>
</Created>
</AuthorInfo>
<Devices>
<Device>
<ID>ID_ProductID_C633</ID>
<Name>SpaceMouse Enterprise</Name>
<Settings>
<OverallScale>1.0000</OverallScale>
<LCDIntensity>100</LCDIntensity>
<ButtonStyle>IconsAndText</ButtonStyle><TextSize>Small</TextSize>
</Settings>
<ButtonBank Default="true">
<ID>Default</ID>
<Button><Input><ActionID>HIDButton_103</ActionID></Input><Output><ActionID>Driver_Desktop_ToggleGrab</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_104</ActionID></Input><Output><ActionID>Macro_Copy</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_105</ActionID></Input><Output><ActionID>Macro_Paste</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_176</ActionID></Input><Output><ActionID>Printscreen</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_11</ActionID></Input><Output><ActionID>Driver_ShowDriverGUI</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_5</ActionID></Input><Output><ActionID>Macro_MaximizeWindow</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_6</ActionID></Input><Output><ActionID>Next_Screen</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_3</ActionID></Input><Output><ActionID>Macro_QuitProgram</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_27</ActionID></Input><Output><ActionID>Driver_ToggleDominantFilter</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_37</ActionID></Input><Output><ActionID>Macro_AlignWindowRight</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_36</ActionID></Input><Output><ActionID>Macro_AlignWindowLeft</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_1</ActionID></Input><Output><ActionID>HIDMouse_Left</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_2</ActionID></Input><Output><ActionID>HIDMouse_Right</ActionID></Output></Button>
</ButtonBank>
</Device>
</Devices>
<UI>
<ButtonFlyouts>
<Category Sort="false">
<ID>UI_3Dx</ID>
<Name>STR_UI_3DX</Name>
<ButtonAction><ID>Driver_ShowDriverGUI</ID></ButtonAction>
<ButtonAction><ID>Driver_Toggle_3DxNumPad</ID></ButtonAction>
<ButtonAction><ID>Driver_Toggle_3DxLCD</ID></ButtonAction>
<ButtonAction><ID>Driver_DecreaseAppScale</ID></ButtonAction>
<ButtonAction><ID>Driver_IncreaseAppScale</ID></ButtonAction>
<ButtonAction><ID>Driver_ToggleTranslations</ID></ButtonAction>
<ButtonAction><ID>Driver_ToggleRotations</ID></ButtonAction>
<ButtonAction><ID>Driver_ToggleDominantFilter</ID></ButtonAction>
<ButtonAction><ID>Driver_Disabled</ID></ButtonAction>
<ButtonAction><ID>Driver_Start_FileManager</ID></ButtonAction>
<ButtonAction><ID>Driver_Start_Browser</ID></ButtonAction>
<ButtonAction><ID>Driver_Desktop_ToggleGrab</ID></ButtonAction>
</Category>
<ID>UI_Macros</ID>
<Name>STR_UI_MACROS</Name>
<ButtonAction><ID>Macro_Search</ID></ButtonAction>
<ButtonAction><ID>Macro_LockScreen</ID></ButtonAction>
<ButtonAction><ID>Macro_TaskManager</ID></ButtonAction>
<ButtonAction><ID>Macro_TabApplication</ID></ButtonAction>
<ButtonAction><ID>Macro_AlignWindowLeft</ID></ButtonAction>
<ButtonAction><ID>Macro_AlignWindowRight</ID></ButtonAction>
<ButtonAction><ID>Macro_MaximizeWindow</ID></ButtonAction>
<ButtonAction><ID>Macro_MinimizeAll</ID></ButtonAction>
<ButtonAction><ID>Macro_QuitProgram</ID></ButtonAction>
<ButtonAction><ID>Macro_FileManager</ID></ButtonAction>
<ButtonAction><ID>Macro_InternetBrowser</ID></ButtonAction>
<ButtonAction><ID>Settings</ID></ButtonAction>
<ButtonAction><ID>Macro_Copy</ID></ButtonAction>
<ButtonAction><ID>Macro_Paste</ID></ButtonAction>
</Category>
<ID>UI_Mouse</ID><Name>STR_UI_MOUSE</Name>
<ButtonAction><ID>HIDMouse_Left</ID></ButtonAction>
<ButtonAction><ID>HIDMouse_Middle</ID></ButtonAction>
<ButtonAction><ID>HIDMouse_Right</ID></ButtonAction>
<ButtonAction><ID>HIDMouse_Forward</ID></ButtonAction>
<ButtonAction><ID>HIDMouse_Backward</ID></ButtonAction>
<ButtonAction><ID>Macro_DoubleClickLeft</ID></ButtonAction>
<ButtonAction><ID>Macro_DoubleClickMiddle</ID></ButtonAction>
</Category>
<Category>
<ID>UI_RadialMenus</ID>
<Name>STR_UI_RADIALMENUS</Name>
<ButtonAction><ID>Base_RadialMenu_MenuRM1</ID></ButtonAction>
<ButtonAction><ID>Base_RadialMenu_MenuRM2</ID></ButtonAction>
<ButtonAction><ID>Base_RadialMenu_MenuRM3</ID></ButtonAction>
</Category>
</ButtonFlyouts>
</UI>
</Global>Code: Select all
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<AppCfg Default="false" xmlns="" CfgFormatVersion="1.3" ThisFileVersion="1.9">
<AppInfo>
<Signature>
<Name>General</Name>
</Signature><Options/>
</AppInfo>
<CfgProperties>
<ID>ID_Desktop_Cfg</ID>
<InheritsFromID>ID_Desktop_Cfg</InheritsFromID>
<Grab>Hard</Grab>
</CfgProperties>
<AuthorInfo>
<LastChange>
<Date>2020:7:5:3:11:47:54:852</Date>
<User>dkyndt</User>
</LastChange>
<Created>
<Date>2020:7:4:2:12:6:32:113</Date>
<User>dkyndt</User>
</Created>
</AuthorInfo>
<MacroTable>
<MacroEntry>
<ID>Settings</ID>
<Sequence>
<KeyPress>E3</KeyPress>
<KeyPress>C</KeyPress>
<KeyRelease>C</KeyRelease>
<KeyRelease>E3</KeyRelease>
</Sequence>
</MacroEntry>
<MacroEntry>
<ID>PresentationMode</ID>
<Sequence>
<KeyPress>13</KeyPress>
<KeyRelease>13</KeyRelease>
</Sequence>
</MacroEntry>
<MacroEntry>
<ID>Sysinfo</ID>
<Sequence>
<KeyPress>0</KeyPress>
<KeyRelease>0</KeyRelease>
</Sequence>
</MacroEntry>
<MacroEntry>
<ID>Start Menu</ID>
<Sequence>
<KeyPress>E0</KeyPress>
<KeyPress>29</KeyPress>
<KeyRelease>29</KeyRelease>
<KeyRelease>E0</KeyRelease>
</Sequence>
</MacroEntry>
</MacroTable>
<ButtonActions xmlns:driver_images="./images/3DxService/" xmlns:device_images="C:\Users\dkyndt\AppData\Roaming\3Dconnexion\3DxWare\Cfg\Images\">
<ButtonAction Type="App">
<Name>Project</Name>
<Arg>None</Arg>
<Image>
<Source>[driver_images:PresentMode.png]</Source>
</Image>
</ButtonAction>
<ID>Taskmgr</ID>
<Name>Task Manager</Name>
<Arg>None</Arg>
<Image>
<Source>[driver_images:Taskmgr.png]</Source>
</Image>
</ButtonAction>
<ID>Driver_Start_3DxViewer</ID>
<Name>STR_DRIVER_START3DXVIEWER</Name>
<Image>
<Source>[driver_images:Viewer.png]</Source>
</Image>
</ButtonAction>
<ButtonAction Type="Exe">
<ID>EXE_Start_Sysinfo32</ID>
<Name>System Information</Name>
<Executable>msinfo32.exe</Executable>
<Arg>None</Arg>
<Image>
<Source>[driver_images:SysInfo.png]</Source>
</Image>
</ButtonAction>
<ID>Settings</ID>
<Name>Settings</Name>
<Arg>None</Arg>
<Image>
<Source>[driver_images:Settings.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_CMD</ID>
<Name>CMD</Name>
<Executable>CMD.EXE</Executable>
<Arg>None</Arg>
<Image>
<Source>[device_images:PROG_CMD.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_Notepad</ID>
<Name>Notepad</Name>
<Executable>start NOTEPAD++</Executable>
<Arg>None</Arg>
<Image>
<Source>[device_images:PROG_NPP.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_Everything</ID>
<Name>Everything</Name>
<Executable>C:\Program Files\Everything\Everything.exe</Executable>
<Arg>None</Arg>
<Image>
<Source>[device_images:PROG_Everything.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_NPP</ID>
<Name>NP++</Name>
<Executable>C:\Program Files\Notepad++\notepad++.exe</Executable>
<Arg>None</Arg>
<Image>
<Source>[driver_images:notepad.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_Paint</ID>
<Name>Paint</Name>
<Executable>MSPAINT.EXE</Executable>
<Arg>None</Arg>
<Image>
<Source>[driver_images:mspaint.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_calc</ID>
<Name>Calculator</Name>
<Executable>calc.EXE</Executable>
<Arg>None</Arg>
<Image>
<Source>[driver_images:calc.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_Outlook</ID>
<Name>Outlook</Name>
<Executable>outlook.EXE</Executable>
<Arg>None</Arg>
<Image>
<Source>[device_images:PROG_outlook.png]</Source>
</Image>
</ButtonAction>
<ID>EXE_Start_Vivaldi</ID>
<Name>Vivaldi</Name>
<Executable>C:\Users\dkyndt\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Vivaldi.lnk</Executable>
<Arg>None</Arg>
<Image>
<Source>[device_images:PROG_Vivaldi.png]</Source>
</Image>
</ButtonAction>
<Name>Toggle 2D 3D mode</Name>
</ButtonAction>
</ButtonActions>
<Settings/>
<Devices>
<Device>
<AxisFilter>None</AxisFilter>
<CurrentButtonBank>Default</CurrentButtonBank>
<CurrentAxisBank>Default</CurrentAxisBank>
<AxisBank Default="true">
<Name>STR_DEFAULT_BANK</Name>
<ID>Default</ID>
<Axis><Enabled>true</Enabled>
<Input><ActionID>HIDMultiAxis_Rx</ActionID><Min>-512</Min><Max>511</Max></Input>
<Output><ActionID>HIDMouse_Y</ActionID></Output></Axis>
<Input><ActionID>HIDMultiAxis_Ry</ActionID><Min>-512</Min><Max>511</Max></Input>
<Output><ActionID>HIDMouse_X</ActionID><Reversed>true</Reversed></Output></Axis>
<Input><ActionID>HIDMultiAxis_Rz</ActionID><Min>-512</Min><Max>511</Max></Input>
<Output><ActionID>HIDMouse_Wheel</ActionID><Scale>1.0000</Scale><Reversed>true</Reversed></Output></Axis>
<Input><ActionID>HIDMultiAxis_X</ActionID><Min>-512</Min><Max>0</Max><Deadband>200</Deadband></Input>
<Output><ActionID>KB_Keystroke</ActionID><RepeatStyle>PressAndHold</RepeatStyle><KeyStroke><Key>50</Key></KeyStroke></Output></Axis>
<Input><ActionID>HIDMultiAxis_X</ActionID><Min>0</Min><Max>511</Max><Deadband>200</Deadband></Input>
<Output><ActionID>KB_Keystroke</ActionID><RepeatStyle>PressAndHold</RepeatStyle><KeyStroke><Key>4F</Key></KeyStroke></Output></Axis>
<Input><ActionID>HIDMultiAxis_Y</ActionID><Min>0</Min><Max>511</Max><Deadband>200</Deadband></Input>
<Output><ActionID>KB_Keystroke</ActionID><RepeatStyle>PressAndHold</RepeatStyle><KeyStroke><Key>51</Key></KeyStroke></Output></Axis>
<Input><ActionID>HIDMultiAxis_Y</ActionID><Min>-512</Min><Max>0</Max><Deadband>200</Deadband></Input>
<Output><ActionID>KB_Keystroke</ActionID><RepeatStyle>PressAndHold</RepeatStyle><KeyStroke><Key>52</Key></KeyStroke></Output></Axis>
<Input><ActionID>HIDMultiAxis_Z</ActionID><Min>-512</Min><Max>511</Max><Deadband>100</Deadband></Input>
<Output><ActionID>HIDMouse_Wheel</ActionID><Scale>1.0000</Scale><Reversed>true</Reversed><Modifiers><Modifier>Control</Modifier></Modifiers></Output></Axis>
</AxisBank>
<ID>Default</ID>
<Button><Input><ActionID>HIDButton_14</ActionID></Input><Output><ActionID>EXE_Start_CMD</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_15</ActionID></Input><Output><ActionID>EXE_Start_Vivaldi</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_78</ActionID></Input><Output><ActionID>Macro_TaskManager</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_104</ActionID></Input><Output><ActionID>Driver_ToggleDominantFilter</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_20</ActionID></Input><Output><ActionID>EXE_Start_Everything</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_21</ActionID></Input><Output><ActionID>EXE_Start_Notepad</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_18</ActionID></Input><Output><ActionID>Macro_QuitProgram</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_19</ActionID></Input><Output><ActionID>EXE_Start_Outlook</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_16</ActionID></Input><Output><ActionID>Macro_AlignWindowLeft</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_17</ActionID></Input><Output><ActionID>Macro_AlignWindowRight</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_22</ActionID></Input><Output><ActionID>HIDMouse_Backward</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_77</ActionID></Input><Output><ActionID>HIDMouse_Forward</ActionID></Output></Button>
<Button><Input><ActionID>HIDButton_13</ActionID></Input><Output><ActionID>Macro_FileManager</ActionID></Output></Button>
</ButtonBank>
</Device>
</Devices>
</AppCfg>Can you please help me out.
I have a bit knowledge of XML, and understand what to do, However I'm pretty stuck on this now.
Thanks.
