Hi, I have a small issue regarding Adobe Reader X. When I have Adobe Reader 9, both 3D content and 2D content is controllable through SPP. Then Adobe issued Adobe Reader update, my SPP stopped working. I've made sure that the "3DxAcr3d.api" file is indeed "installed" in the plug_ins folder, yet when I open Adobe Reader's plugin list, it doesn't show up... And yes, I've installed/re-installed more than 3 times already...
Any idea(s) is appreciated, thanks in advance...
zzz2496
Adobe Reader X not recognizing SPP
How to enable support for the 3D mouse in Adobe Reader X
Reader X introduced new security measures which prevent plugins from accessing certain low level functionality in the OS. This restriction affected our plugin's ability to communicate with the driver. As a result, the plugin could not establish a connection with the driver to receive events.
As long as we have not yet adapted our plugin for Adobe Reader X we can suggest a workaround is to disable this additional Reader security. Go to Edit->Preferences->General and unchecking "Enable Protected Mode at startup"
Please note that you change the settings in Adobe Reader X on your own risk!
Adobe X reader and spaceexplorer
I am having the same problem in Vista 32. changing the security setting as described did not help.
Any other suggestions?
