I still "like" it, but the number of quorky things I have to deal with I am having fleeting thoughts of returning it. The time that it saves is almost made up for in the problems. I would really like to see if anyone else is having issues.
Our Render Box front end is as follows:
Software: 3DS Max 2011 with 3DS Design 2011
CPU: Intel i5 660 3.333Ghtz
RAM: 8GB
OS: Windows 7 Ultimate MSDN Subscription 64-bit
Video: nVidia GeForce GTS 250 1GB Ram model
Drives: 3 120GB Solid State One dedicated for swaps and page files
I have only been using this for two days, but here is a list of my current issues - Hopefully someone can tell me it is something I am doing and not this 3D mouse.
1) Perspective view acts different - When 3DS starts with default perspective view if is useless to use this view and the view buttons. Things simple just get scaled out of range a lot. It just gets way out of wack too fast and the "fit" button doesn't fit. So I have to jump to User view to get the functionality I am wanting. This one may be me not used to the 3D mouse....
2) Slow to use - It is really slow to respond sometimes. I am going to try increasing the sensitivity and see what that gets me. However, quite often I click on something now and have to wait (sometimes a couple seconds) before what I clicked is activated. This really ticks me off especially on this high end of a box.
3) Smooth view gets jacked - If I am in "Smooth w Highlights" view and I have an object comprising multiple sub-objects the colors get all scrambled together. Then if I go to the mouse and move everything just a hair it all goes back to the way it should be. Which negates the point of having the device to start with it I have to tweak a view each time with a mouse!
4) Stop it! - This is the real issue for me. We have a number of custom ribbons that we use as short cuts for tools. If I select say Create->Sphere, then create a sphere it does. However.....it stays in that mode and if I click on anything else it draws another one. So I ALWAYS have to right click after using a tool to stop it from continuing to use the tool. This is the primary issue that is making me want to return this thing.
p.s. I can even access say create->box from the traditional menu the normal way and it still does this so it isn't our ribbon.
I hope someone can help me with this thing soon or it is going back
