Space Navigator Driver with Unity dropdown
Re: Space Navigator Driver with Unity dropdown
I see you are using TDxInput code. If you are starting with one of the projects from the Unity store, some have default joystick actions defined that always map some axes to actions that cause constant motion. I forget the details of it. It is a project setting that you need to remove.
