I use a SpaceMouse Pro at work (medical imaging) where we use Windows. We can work from home via VMWare and a thinclient which works fine most of the time. I have my own iMac with VMWare installed but I can't get the SpaceMouse to work even though the drivers are installed in the virtual Windows environment. It seems to be a general issue with recognising USB devices because the same happens with my Jabra headset.
Any solutions?
Using SpaceMouse Pro on Vmware via iMac
Re: Using SpaceMouse Pro on Vmware via iMac
You may have to forward your USB port, try VirtualHere to forward your USB port.
https://www.virtualhere.com/
That might work, though it seems installing the Mac version of the driver is another issue. I can install the package but then I get a message some security setting (forgot which one exactly) must be set to "allow" only that button doesn't appear when I go to security on my Mac. (MacOS Big Sur).luping wrote: ↑Thu Dec 10, 2020 10:38 pm You may have to forward your USB port, try VirtualHere to forward your USB port.
Hi papagena,
You're using a version of the driver that will not work on macOS 11 and you may want to install the "beta" of v. 10.7.0 instead. Please refer to this topic.
papagena wrote: ↑Fri Dec 11, 2020 5:50 amThat might work, though it seems installing the Mac version of the driver is another issue. I can install the package but then I get a message some security setting (forgot which one exactly) must be set to "allow" only that button doesn't appear when I go to security on my Mac. (MacOS Big Sur).luping wrote: ↑Thu Dec 10, 2020 10:38 pm You may have to forward your USB port, try VirtualHere to forward your USB port.
The newest MacOS 11 Big Sur is a bit new for various third-party ISVs and hardware OEMs, there's a delay for compatible driver update...OSX: VirtualHere Client for OSX 10.9.5 / 10.10 / 10.12 / 10.13 / 10.14 (partial) / (10.15+ not supported)
https://www.virtualhere.com/usb_client_software
