MacOS Big Sur Sleep Issue.
I am using a mac pro running Big Sur 11.1. I have the 3Dconnexion SpaceMouse Enterprise and I am noticing two issue. The first is the mouse prevents my computer from going to sleep. The second is the mouse does not work with FreeCad. Is there something I am missing? Is there a setting that will fix the issue with the computer not going to sleep? Also will you be fixing the issue with FreeCad?
Re: MacOS Big Sur Sleep Issue.
Hi dblock,
Is the device constantly sending data ("drifting")? For example, do see a continuous movement in an application?
If I'm not mistaken, it is necessary to build FreeCad on a Mac with the 3Dconnexion drivers already installed: the build tool will detect the driver and automatically enable support for 3D mouse.The second is the mouse does not work with FreeCad. Is there something I am missing? Is there a setting that will fix the issue with the computer not going to sleep? Also will you be fixing the issue with FreeCad?
