Spacemouse pro wireless keyshot 10
rancheus
Post by rancheus »
I'm trying to get Spacemouse pro WL to work with Keyshot 10 on Macos Big Sur, newest beta.
3DConnexion settings in keyshot are greyed out, I've manually added keyshot 10 to the 3dconnexion pref pane. The Spacemouse is not responding at all in keyshot.
Any suggestions?
Screenshot 2021-02-17 at 14.42.06.png (74.76 KiB) Viewed 4533 times
Re: Spacemouse pro wireless keyshot 10
rancheus wrote: ↑Wed Feb 17, 2021 6:42 am 3DConnexion settings in keyshot are greyed out, I've manually added keyshot 10 to the 3dconnexion pref pane. The Spacemouse is not responding at all in keyshot.
Exit from KeyShot and then remove the "3DconnexionClient.framework" file in the following location:
/Applications/KeyShot10.app/Contents/Frameworks/
If using Terminal, simply run:
sudo rm /Applications/KeyShot10.app/Contents/Frameworks/3DconnexionClient.framework
After that, start KeyShot and check if the problem is fixed.
The "framework" file shouldn't be included in the KeyShort installation. We're told the issue is fixed in KeyShot 10.1.
