Every once in a while when I'm using my SMPW I will begin hearing a rapid clicking sound on my Mac as if a keyboard button is being held down. I always simply restarted but this is not a long term solution so I began to investigate the cause. When it happened again I began to one by one, unplug connections from my machine but the noise persisted until I removed the SMP wireless dongle. When I remove it, it stops and I can plug it back in to continue working. But at some point it will happen again and I remove it again. I believe it's triggering the option button.
Is this a known issue?
Mac Pro 2019
macOS 10.15.7
SpaceMouse Pro Wireless Second Generation
3DxWare 10.6.7
SMPW rapidly pressing keyboard button
Re: SMPW rapidly pressing keyboard button
Hi jesse.art,
Connect your SMPW with a cable and use it for a couple of days. This will remove one variable (the receiver dongle) from the picture and may point out where the problem might be.
I can't immediately recall this ever happening with driver 10.6.x or older (there's a similar but unrelated issue on driver 10.7.0 but that's macOS 11 -specific).
Been using the SMPW strictly through usb without the dongle plugged in and I still get similar issues. I have to unplug the cable, turn the SM off and back on then plug the usb back in and it works fine again until the next time. I really hope this gets fixed in a driver update soon.
Yeah. This happens often enough and with the amount of troubleshooting Ive done, I've got it narrowed down to a bug within the SM environment-whether that be a software issue or hardwire I do not know.
It's the same thing every time. UI glitch, unplug SM and turn it off, plug it back in, turn it on, problem goes away for a few hours.
But man outside of that I love using it with ZBrush.
