Space Navigator not working in AutoCad MEP 2010
When I start AutoCad I get an error message. Unhandled Exception E06D7363 (e06d7363h) at address 7C812AFBh. I have the new drivers and software installed. How can I fix this?
Hello bryork88 -
To determine whether the error is connected to the 3Dconnexion software [3dxautocad.arx] you can remove the add-in by de-selecting it in Add/Remove Software. [Windows ControlPanel- Add/Remove Software – 3Dconnexion – Change|Modify] If you start AutoCAD and do not see the error without the add-in, a Clean Install of the 3Dconnexion software is recommended to remove any possible data corruption in a custom profile or a registry key.
_________________
Barbara
_________________
Barbara
