Rhino swap tilt and roll
barneym
Post by barneym »
I’ve recently moved to a windows machine and need to swap the tilt and roll axis which I’ve become accustomed to using over many years. On my mac I can easily swap this in preferences.
I have previously edited a config file to achieve the same in windows. This time I’ve found the Rhino xml file that needs editing but the syntax is different. Can someone help?
Best,
Barney
barneym
Re: Rhino swap tilt and roll
Post by barneym »
Everytime I close Rhino and then reopen the 3D connexion software has forgotten my settings. At this point I haven't edited the config file this is just the standard behavior in the app
Form a new habit, reverse your tilt and roll axis swap, it's not insurmountable, it only needs at least 21 days to form a new habit. :D
You're an adaptable man, you can change your habit.
