Solidworks as administrator
Nebohadnazzer
Post by Nebohadnazzer »
hi Guys,
a seem to have a weird one...
when I run solidworks (2017 to 2020) as administrator my space mouse enterprise isn't working.
the screen is showing SW but non of the buttons work nor the joystick. when I open a part/assy the moues doesn't recognize it.
any ideas what is causing this?
thanks for the help...
Re: Solidworks as administrator
What version of 3DxWare?
You should have received a notification about this conflict in the Action Center.
If you run Solidworks at a higher UAC level than the driver, the driver can't talk to it. You need to run 3DxService.exe at the same level (run as administrator). It isn't recommended.
Try follow my advice:
Keyboard Win+R
Input secpol.msc, run as Administrator
Go to Local Policies>security options>
Make sure to disable "User Account Control: Run all administrators in Admin Approval Mode"
Nebohadnazzer wrote: ↑Sun Apr 04, 2021 2:38 am when I run solidworks (2017 to 2020) as administrator
We have seen this before but we don't know why customers run SOLIDWORKS as administrator (elevated). Running any application elevated carries a security risk and should be done only in very specific cases (like changing passwords or accessing a restricted configuration file).
Can you tell us why do you need to run the application with administrator privileges?
Nebohadnazzer
hello,
Thank you all for the replies.
I was running in administrator because of frequent changes in solidworks preferences while configuring a new PC.
I decided to NOT open SW as admin to prevent the issue
Thanks guys!
8)
Nebohadnazzer wrote: ↑Tue Apr 27, 2021 6:13 am I was running in administrator because of frequent changes in solidworks preferences while configuring a new PC.
I see. Thank you for giving us the context of why you needed to run the application as administrator (setting system-wide preferences).
Chris3DStolle
Post by Chris3DStolle »
luping wrote: ↑Mon Apr 05, 2021 2:50 am Try follow my advice:
Keyboard Win+R
This was exactly what I needed! 3DConnexion appears to have terrible support! They deleted my post when I asked about this. In this support thread it does say they both need to be running as non-elevated which was accurate and helpful. However, they did not explain how to do this! One minor detail they missed. :roll:
