Photoshop Plugin work but jerky
burggraben
Post by burggraben »
Photoshop v22.3.1
3DxPhotoshop v 2.9.5
The plugin finally supports Photoshop (Thanks, greatly appreciated!)
However, several issues:
Issue 1: I find the movement to be incredibly jerky. If I load an image into And Autodesk Product (say Inventor) I can pan and zoom around that image buttery smooth. Howver in Photoshop if I pull with contanst tension to zoom in, the movement smarts, it will stop for a half second, and then continue, without the tension that I have applied to the image every changing. Any idea if my setting are worng or if the driver need improvement?
Issue 2: I can't seem to pan and zoon simulatelously. If I move the navgiator in that way, then the driver will jump between panning and zooming discretely, rather than applying movements simulatneously like it does in Autodesk products.
Issue 3: When zooming out the image also auto centers itself when it is zoomed out far enough to to fit the view space. Might be a photoshop configuratino thing only?
Question 1: Also it ask me to a assign a keyboard shortcut to the plugin, which I did, but the shortcut doesn't seem to do anything?
