Our company has implemented 3D Connexion API in our code similar to the way it is implemented in Cube3DPolling sample application. However on one customer WinXP 32 bit machine the call get_Sensor crashed. The machine was using SpaceNavigator mouse with driver installed about two years back. He had a few configurations saved in the driver. I couldnt get an opportunity to find many details on the customer machine, however I would be interested to know if some similar crash has been observed on call to get_Sensor?
I am writing the InitializeCOM code here.
Should I cover the InitializeCOM call in our code in try/catch.
HRESULT CView3DComEventReceiver::InitializeCOM()
HRESULT hr=S_OK;
CComPtr<IUnknown> _3DxDevice;
// Create the device object
if (!s_p3DxDevice)
hr = _3DxDevice.CoCreateInstance(__uuidof(Device));
s_p3DxDevice = _3DxDevice;
else
s_p3DxDevice->AddRef();
_3DxDevice.Attach(s_p3DxDevice);
if (SUCCEEDED(hr))
CComPtr<ISimpleDevice> _3DxSimpleDevice;
hr = _3DxDevice.QueryInterface(&_3DxSimpleDevice);
if (SUCCEEDED(hr))
// Set the preferences we want to use
_3DxSimpleDevice->LoadPreferences(L"Ansoft");
// Get the interfaces to the sensor and the keyboard;
if (!m_pISensor)
hr = _3DxSimpleDevice->get_Sensor(&m_pISensor);
if (SUCCEEDED(hr))
hr = __hook(&_ISensorEvents::SensorInput, m_pISensor, &CView3DComEventReceiver::OnSensorInput);
else
AnsDebug(2, ACHAR("Could not connect to SensorInput of 3D Mouse Device, get_Sensor failed\n"));
if(!m_pIKeyboard)
hr = _3DxSimpleDevice->get_Keyboard(&m_pIKeyboard);
if (SUCCEEDED(hr))
hr = __hook(&_IKeyboardEvents::KeyDown, m_pIKeyboard, &CView3DComEventReceiver::OnKeyDown);
hr = __hook(&_IKeyboardEvents::KeyUp, m_pIKeyboard, &CView3DComEventReceiver::OnKeyUp);
else
AnsDebug(2, ACHAR("Could not connect to Keyboard of 3D Mouse Device, get_Keyboard failed\n"));
// Connect to the driver
hr = _3DxSimpleDevice->Connect();
if (!SUCCEEDED(hr))
AnsDebug(2, ACHAR("Could not connect to 3D Mouse Device, Connect failed\n"));
else
AnsDebug(2, ACHAR("Could not QueryInterface 3D Mouse Device, QueryInterface failed\n"));
//_3DxDevice.Release();
else
//::MessageBox (NULL, _T("Could not Create 3D Mouse Device"), _T("CoCreateInstance failed"), MB_ICONERROR|MB_OK);
AnsDebug(2, ACHAR("Could not Create 3D Mouse Device, CoCreateInstance failed\n"));
_3DxDevice.Detach();
return hr;
Nihit
