Window caption aware buttons
davykyndt
Post by davykyndt »
I was reading this discussion about caption aware profiles.
https://forum.3dconnexion.com/viewtopic ... 25&t=33600
It is stated that you need to create multiple profiles for each window caption.
Can you please explain a bit on how to implement such thing?
Do I need to make one XML file that loads when I open the program, and make shortcuts from in there?
Of should I make one large XML with all shortcuts per window caption?
Best Regards
Davy
Re: Window caption aware buttons
I need a bit more context to answer that.
What application?
What are the specifics about the request?
An example?
