SpaceMouseCompact Rhinoceros6 and HighSierra
FaberFaberrimus
Post by FaberFaberrimus »
System info:
  • iMac 27" HighSierra 10.13.6
    3DWare 10.6.7 (MacCore v 1.1.6)
    SpaceMouse Compact FW 4.37
    Rhinoceros3d V. 6.34.21034.07002, 2021-02-03
I'm not having success in making the two buttons of the SpaceMouseCompact work as desired.
Various posts found on this forum and on Mcneel are not pointing me in a right direction. Mostly because it seems to me that they refer to previous Rhino 5 version. (For instance, Many time it's suggested to set Rhino preferences with button 1 to command !_SpaceMouse Popup_Menu which is not available for RH6 Mac).
That said what I find strange is: when in Rhino pref/3Dconnexion, if I click left or right buttons sometimes they do highlight some other not. Why?
In the attached picture you can see the Butt1 highlighted, but the right won't.
(this is with 3Dconnexion control Panel in DEFAULT).
Schermata 2021-06-11 alle 12.41.43.jpg (106.11 KiB) Viewed 3425 times
I'm obviuosly making something that is not going as it should because some combinations works and other not.
FaberFaberrimus
Re: SpaceMouseCompact Rhinoceros6 and HighSierra
This is is another setup combination:
Trying to map both buttons to two different radial menus, well this time left button will not popup anything. While the right one will.
Left Button
Left Button
Schermata 2021-06-11 alle 12.46.25.jpg (56.67 KiB) Viewed 3409 times
Right Button
Right Button
Schermata 2021-06-11 alle 12.46.32.jpg (57.31 KiB) Viewed 3409 times
Schermata 2021-06-11 alle 12.46.44.jpg (80.87 KiB) Viewed 3409 times
