Hello
This line has appeared in the release notes for the 10.8.2 driver.
"New: Add configuration for Epic Games Twinmotion."
Except there is no plugin folder included in the driver for Twinmotion.
Twinmotion configuration included in 10.8.2 driver
peterbowenpm
Re: Twinmotion configuration included in 10.8.2 driver
Hi peterbowenpm,
Have you tried using our device with Twinmotion? Did the navigation work or buttons?
Regards,
Abdul. A
Regards,
Abdul. A
peterbowenpm
Hello
No response from any movement or buttons on the SpaceMouse Enterprise in Twinmotion.
Hi peterbowenpm ,
I've seen that there's an update for Twinmotion to be included in Oct and our driver has a default config file for this application in C:\Program Files\3Dconnexion\3DxWare\3DxWinCore\Cfg
We can check on our end to see! Can you please get a log file by following this FAQ here https://3dconnexion.com/us/support/faq/ ... r-windows/ then create a technical case and submit the file here https://3dconnexion.com/us/support-request/
Regards,
Abdul. A
Regards,
Abdul. A
