SketchUp 6 Camera-Mode inversion
alz
Post by alz »
(with latest/beta driver)
I've reversed all axis to treat the SpaceExplorer like a joystick or steering wheel in SketchUp. This works great!
...except for in Camera Mode, which seems to ignore the reverse flag, defaulting movement back to spin-left=turn-right.
Turning off Camera Mode returns movement to its original reversed-axis.
Is there some internal switch, flag, or .ini setting I'm overlooking to propagate settings across the board?
TIA :)
Hi alz,
"Camera mode" means that you are controlling the "camera" used to display the view. If you're controlling a "camera", then the sense of the axes are reversed when in "Object mode". This reversion is by definition.
