new drivers
flaviosendo
new drivers
Post by flaviosendo »
hello,
i just need information about new drivers.
All applications should be supported even not directly.
but what exactly can I do?
Just map movement to button?
just another information
Can I add new voices on LCD display of Pilot Pro?
I mean the list (outlook, rssfeed ...)
Best Regards
Flavio
With 3DxWare 10, you can map any key from the keyboard, mouse or joystick to any button on the 3D mouse.
You can map any 3D mouse axis to emulate any mouse or joystick axis.
You can also define keys (for example, the arrow keys) to be pressed when you move the device cap.
Finally there is an extension mechanism that you can use to do anything else you can imagine, if you are willing to write some code.
I'm not sure what you mean by "voices", but you can run any Logitech applet on the SpacePilot PRO LCD.
