axis values
vekni
axis values
Post by vekni »
I would like to know what is the range for the axis values?, without any function to do something on the values, my program gives me values between 0 (i guess)min and 65534 (I guess...)max and the center is 32767 (i'm sure of that ^^), are these values ok?
It may depend on which API you are using.
The device generally produces signed values +/- 350-ish (they are not all the same), but the user can scale these values with the software to any valid integer. So don't count on a limited range.
Since you are seeing all positive numbers, it looks like you are using a joystick-type of API. Joysticks run from 0 to 65K from one extreme to the other.
