I noticed on the application compatibility list that Pro/E Wildfire is supported but it does not mention older version of Pro/E. I am currently stuck on Pro/E 2001 and wanted to know if it will work with the SapceNavigator.
Thanks.
Will SpaceNavigator work with Pro/E 2001?
Hi, podemma. Pro/ENGINEER has native support for 3Dconnexion devices. As such, this question should be posed to PTC.
We believe that Pro/E 2001 supports our devices for navigation but the 3Dconnexion plug-in (button mapping feature) is only supported in Wildfire 2.0 and higher.
Re: It Works!
Good stuff. Thanks for keeping all of us in the loop.podemma wrote:I was able to get the Space Navigator to work with my Pro/E 2001. The buttons even work. I also tried a Space Traveler and it worked also. I did not try the buttons on the Space Traveler, but the navigation worked just fine.
