So there are two annoying bugs with 3ds max 2022 and the spacemouse (wired):
1. Once I've switched on my computer and started up 3ds max, the spacemouse works just fine with all the customizations. At some point arbitrarily, the rotation centre gets stuck in 3D space and absolutely nothing helps it get unstuck apart from restarting Max. Another issue here is that regardless of the stuck rotation centre, spacemouse rotates in 3D space around some arbitrary point. Very annoying.
2. The spacemouse just stops working altogether in Max and not even a shutdown of the app, restarting of the driver and reopening of Max gets it going again. Oddly, it works just fine in other 3d apps and chrome.
I'm using the latest driver (10.8.4.3407). This is urgent and any help will be much appreciated.
TIA,
Gareth
Spacemouse with 3ds max 2022 BIG BUGS
