I am using SpaceMouse Wireless Kit 2 since a few months. Initially everything worked fine, but recently mouse scrolling became unusable.
Voila, that is how it looks like (in all applications I use, including Fusion 360):
https://www.youtube.com/watch?v=6OtBXAADlZQ
I tried:
- changing scroll settings - no effect
- drivers update - no effect
- changing connection type (usb dongle/bloetooth/cable) - no effect
- changing polling rate in wired mode - no effect
- I connected my CadMouse Compact Wireless to other PC - same problem
- I connected 20$ mouse to my PC - works great...
- contacting the seller - no effect
Is it fixable?
Erratic scrollig behaviour Windows 11
Re: Erratic scrollig behaviour Windows 11
Hi vanhasen,
please contact our Technical Support Team. The colleagues can start the replacement process if applicable.
Thank you. My problem has been solved, thank you 3Dconnection Team
I have the same problem can you tell me the solution you came up with please
I have the same problem but with the CADMOUSE COMPACT mouse, has anyone managed to find a solution to this problem?
