deviatoin and validatoin
how to find deviation model and cmm points by NX 7.5?
Deviation and validation
Hello badpeima -
Are you trying to find the Deviation Checking dialog box [Analysis- Deviation - Checking] or to map a command to a button ?
To map an NX command, make sure you are using the button mapping editor inside NX. [Customize Buttons from the pop-up menu].
If you are not able to open this editor - if the selection is greyed out - you will need to follow the steps here.
Barbara
Barbara
