Greetings,
I'm currently integrating 3D Connexion controllers into Chaos Vantage using your new SDK.
The problem I'm currently experiencing is that the Panning isn't working. Other camera translations are ok. (Rotation, Zoom)
When I disable all the axis and leave just the Forward/Backward, Left/Right ones (picture attached) the GetCameraMatrix method gets called
but doesn't call back SetCameraMatrix at all.
Note: This is valid for all Navigation Modes
Is the panning implicitly dependent on something to work?
I'd be happy if you give me some pointers/tips on how to handle this.
Best Regards,
Alexander Kostov
Pan not working
Pan not working
- Attachments
- settings.png (19.25 KiB) Viewed 20247 times
Re: Pan not working
This can happen -- by design -- if you're setting the view as non-rotatable (see section 3.4.2.8 on page 12 of the "navlib.pdf" document) or if you have defined a "construction plane" (section 3.4.2.2) with its normal parallel to the camera's "look-at" direction.
