Unreal 4.27.2 SpaceMouse Enterprise no rotation
peterbowenpm
Hello
I have just opened a project in Unreal 4.27.2 and found that I have no rotation with my SpaceMouse Enterprise. I can tumble and yaw, but no rotate. The lock horizon has also gone. I have driver 10.8.5 installed on a windows 10 machine. The 3Dconnexion driver appears as activated in the plugins list as the project was created in a earlier version of 4.27. It is project started with the Archviz template.
The SpaceMouse Enterprise works correctly with SketchUp, Blender and 3DS Max.
Anyone else experienced this behaviour.
Peter
Peter
peterbowenpm
Re: Unreal 4.27.2 SpaceMouse Enterprise no rotation
Hello
Same issue with driver 10.8.6.
Peter
Peter
Can you see a difference when the "Lock Horizon" option is enabled or disabled?
The option is found in the SpaceMouse "Advanced Settings" panel of "3Dconnexion Properties".
peterbowenpm
Hello
All my settings are set the way I want, including lock horizon.
Instead of the expected rotation in object mode around the z axis, the object spins around the x axis.
Peter
Peter
Is the problem only reproducible when "Lock Horizon" is enabled?peterbowenpm wrote: ↑Fri Mar 11, 2022 5:45 am All my settings are set the way I want, including lock horizon.
peterbowenpm
Hello
If I turn off lock horizon then I get my rotation back.
Turn lock horizon back on, same problem.
Peter
Peter
We can see this and we're tracking the bug as WIN-1021.
We're working to include a fix in the next driver update (v. 10.8.7).
WIN-1021 is marked as fixed in v. 10.8.7 of 3DxWare 10.
Version 10.8.7 of 3DxWare 10 for Windows was published today, April 8. It includes a fix for WIN-1021 and support for Unreal Editor 5.0.
The software is available for download from here.
peterbowenpm
