Rotation does not work
Kentona
Post by Kentona »
The rotation function does not work anymore even if it`s enabled.
That can I do to make it work?
I use Catia V5 and Windows 10 with a
DavidV
Re: Rotation does not work
Post by DavidV »
If you haven't done so already, restart your machine and see if that fixes the issue.
If that does not work, then its possible you might need to reset your configuration by deleting the XML sheet for Catia V5.
1. Stop the driver by going to the 3Dconnexion Folder in the start menu and selecting "Stop 3DxWare.
2. Shut down Catia if its running
3. Please follow the link in our FAQ here to learn how to find the configuration files: https://3dconnexion.com/us/support/faq/ ... ion-files/
4. Locate the XML sheet labeled Catia and delete it.
5. After it is deleted close file explorer and restart Catia and our driver and test.
