I have spacepilot pro. I know that it's not properly supported any longer. The new 3dconnexion software (3DxWare64_v10-8-7_r3448) does appear to have a plugin for 2023, but it doesn't appear to be working correctly. Is that because there's a problem with the software, or because it's not supported any longer?
thanx --ds
3dsmax 2023
dennisqdw2
Re: 3dsmax 2023
Update. With the help of someone at 3dconnexion, I was able to get v10.8.7 to work. That's the good news. The bad news is that there's none of the programmable button text on the window of the spacepilot device. He had me install 10.8.4, which was no help on the screen, and also doesn't work on Max 2023. I'll keep you posted if/when I get some more support.
vinayk9909
Re: 3dsmax 2023
Hi, I have been facing a similar issue with my space pilot pro. from the last 4 days or so some of the function keys like top, side, front view buttons don't work. Is it the same issue with yours as well? Do you happen to find out if it's fixable by some software settings or anything?
-Vinay
-Vinay
kundewayne
- Contact:
Re: 3dsmax 2023
I have the same Space Pilot Pro issue. Inoperable function keys include the top, side, and front view buttons for four days. Does your end have the same problem? Has anyone found software changes that may fix the problem?dennisqdw2 wrote: ↑Mon May 09, 2022 4:52 pm I have spacepilot pro. I know that it's not properly supported any longer. The new 3dconnexion software (3DxWare64_v10-8-7_r3448) does appear to have a plugin for 2023, but it doesn't appear to be working correctly. Is that because there's a problem with the software, or because it's not supported any longer?
thanx --ds
Re: 3dsmax 2023
For those who searching - the last driver supported by Logitech LCD is 3DxWare64_v10-7-4_r3350
