Can SpaceNavigator be used in embedded application?
Interested in using SpaceNavigator in an experimental electronic musical instrument. Host is Xilinx FPGA board with USB facilities. Is there an interfacing manual (theory, timing, USB messages, etc)?
That sounds interesting. It is a standard HID Multi-axis Controller. If the USB facilities are low level enough, you should be able to detect it and read it. What you do with the data will be up to you. I'd start off by just trying to get woken up when you press one of the buttons or move the cap. After that we have code on the ftp-us site that shows how to parse it.
Servicing the device is no problem -- the incoming bytes can be observed without human-detectable delays. In principle, your device could provide a supple and expressive musical instrument controller. But a critical issue is update rate and latency: any perceptible delay or jerkiness in response works against this application. Can you tell me anything about this issue?
Re: Can SpaceNavigator be used in embedded application?
We recently did an embedded application using a Microchip PIC32 which serves as the USB host. Got it working in an afternoon and talking to the SpaceNavigator. Used largely the canned functions in the PIC32 libraries. Our software maven said he used a diagnostic tool on a PC to determine the USB data packets. Examining the Linux driver also gave some insight.
Thanks, Oppie. I wonder if you would share the name of the PC diagnostic tool?
